I started the day by priming all the seat components, forward cabin covers and forward canopy decks. While the primer was drying and curing I turned to the flap system. First I fitted the WD-613EF torque tube after drilling out the clevis ends to final size. Then I drilled, cut and installed the F-680 center mounting block for the F-613EF torque tube. Then I frabricated the F-766B, F-785B, F-766C, F-766D and F-767 attaching hardware. With the attaching hardware done I installed and match drilled the F-766A channel and F-785A backrest brace.
Seat components, forward cabin covers and canopy decks primed
